This configuration allows you to map the port with DHCPv6 Guard or RA Guard policy. You can view, create or delete the mappings.
Use this procedure to map a port to a RA Guard or DHCPv6 Guard policy, DHCPv6 Guard or RA Guard statistics.
 - Click FHS.
 - Click the Port Policy Mapping tab.
 - Click Insert.
 - Configure the parameters for the port policy mapping.
 - Click Insert.
 - Optional: Click Refresh to update the results.
Port Policy Mapping Field Descriptions
Use the data in the following table to use the Insert Port Policy Mapping dialog box.
 Name  |
 Description  |
 IfIndex  |
 Specify the port.  |
 DHCPv6GuardPolicyName  |
 Enter an already-created DHCPv6 Guard policy name to map it with the port.  |
 RAGuardPolicyName  |
 Enter an already-created RA Guard policy name to map it with the port.  |
 Dhcpv6gDeviceRole  |
 Select server or client configuration. The default is server.  |
 RagDeviceRole  |
 Select host or router configuration. The default is router.  |
Use this procedure to display port policy mapping information.
 - Click FHS.
Use the data in the following table to use the Port Policy Mapping tab.
 Name  |
 Description  |
 IfIndex  |
 Identifies the port.  |
 Dhcpv6gDeviceRole  |
 Specifies the DHCPv6 Guard device-role of the received port. If the device role is client and if it receives DHCPv6 reply then those packets should be dropped.  |
 Specifies the DHCPv6 Guard policy name associated with the port.  |
 TotalDHCPv6PktRcv  |
 Shows the total number of DHCPv6 packets received on the DHCPv6 Guard enabled interface.  |
 TotalDHCPv6PktDropped  |
 Shows the total number of DHCPv6 packets dropped due to DHCPv6 Guard filtering.  |
 RagDeviceRole  |
 Specifies the RA Guard device-role.  |
 RAGuardPolicyName  |
 Specifies the RA Guard policy name associated with the port.  |
 TotalRAPktRcv  |
 Shows the total number of RA packets received on the RA Guard enabled interface.  |
 TotalRAPktDropped  |
 Shows the total number of RA packets dropped due to RA Guard filtering.  |
 NDInspection  |
 Enables or disables Neighbor Discovery (ND) inspection. The default is disabled.  |
 TotNdPktRcv  |
 Shows the total number of ND packets received on the RA Guard enabled interface.  |
 TotNdPktDropped  |
 Shows the total number of ND packets dropped due to RA Guard filtering.  |
 ClearDHCPGuardStats  |
 Clears, if true, the DHCPv6 Guard statistics for the port.  |
 ClearRAGuardStats  |
 Clears, if true, the RA Guard statistics for the port.  |
 ClearNDInspectStats  |
 Clears, if true, the ND-inspection statistics for the port.  |
Use this procedure to delete the created port policy mapping.
 - Click FHS.
 - Select a row from Port Policy Mapping to delete.
 - Click Delete.
 - Click Apply.
