Configure Limit Learning
Limit MAC address learning to limit the number of forwarding database (FDB) entries learned on a particular port to a user-specified value. After the number of learned forwarding database entries reaches the maximum limit, MAC learning stops at that port.
- On the Device Physical View tab, select one or more ports.
 - Select General.
 - Select the Limit-Learning tab.
 - Configure the parameters as required.
 - Select Apply.
Limit Learning Field Descriptions
Use the data in the following table to use the Limit-Learning tab.
                                 Name  |
                                 Description  |
                                 PortNum  |
                                 Shows the slot and port number to configure.  |
                                 MaxMacCount  |
                                 Configures the number of entries in the MAC table for the port that causes learning to stop. The default is 1024.  |
                                 CurrentMacCount  |
                                 Shows the number of entries currently in the MAC table for the port.  |
                                 Enable  |
                                 Enables or disables limit learning for the port. The default is disable.  |
                                 MacLearning  |
                                 Shows if MAC learning is enabled or disabled for the port.  |
