Configure IPv6 route preferences to give preference to routes learned for a specific protocol.
Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. Change a prefix list or a routing protocol before you activate the protocols.
Configure the route preference to RIPng and confirm the configuration is correct.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#ipv6 route preference protocol ripng 10
Switch:1(config)#show ipv6 route preference
                                IPv6 Route Preference - GlobalRouter
PROTOCOL        DEFAULT    CONFIG
LOCAL           0          0
STATIC          5          5
SPBM_L1         7          7
OSPFv3_INTRA    20         20
OSPFv3_INTER    25         25
EBGP            45         45
RIPNG           100        100
OSPFv3_E1       120        120
OSPFv3_E2       125        125
IBGP            175        175
Variable definitions
Use the data in the following table to use the ipv6 route preference and the show ipv6 route preference commands.
 Variable  |
 Value  |
 <0-255>  |
 Assigns a route preference value.  |
 ebgp  |
 Configures the preference for protocol type EBGP.  |
 ibgp  |
 Configures the preference for protocol type IBGP.  |
 ospfv3-extern1  |
 Configures the preference for protocol type OSPFv3 external type 1.  |
 ospfv3-extern2  |
 Configures the preference for protocol type OSPFv3 external type 2.  |
 ospfv3-intra  |
 Configures the preference for protocol type OSPFv3 intra-area.  |
 ospfv3-inter  |
 Configures the preference for protocol type OSPFv3 inter-area.  |
 ripng  |
 Configures the preference for protocol type RIPng.  |
 spbm-level1  |
 Configures the preference for protocol type spbm-level1.  |
 static  |
 Configures the preference for protocol type static.  |
