This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the SPBM Service Instance Identifier (I-SID) information. The SPBM B-MAC header includes an I-SID with a length of 24 bits. This I-SID can be used to identify and transmit any virtualized traffic in an encapsulated SPBM frame.
- Select SPBM Remote.
- Select the I-SID tab.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
I-SID Field Descriptions
Use data in the following table to use the I-SID tab.
Name |
Description |
SysId |
Indicates the system identifier. |
Vlan |
Indicates the B-VLAN where the remote I-SID is configured or discovered. |
Isid |
Indicates the remote IS-IS SPBM I-SID identifier. |
NickName |
Indicates the nickname of the node where the remote I-SID is configured or discovered. |
HostName |
Indicates the host name listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if you do not configure the host name. |
Type |
Indicates the remote SPBM I-SID type. The values are discover or configure. |
