This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote IS-IS interfaces. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
 - Select IS-IS Remote.
 - Select the Interfaces tab.
 - Select Insert to create a remote IS-IS instance.
 - Configure the IS-IS interface parameters.
 - Select Insert.
Interfaces Field Descriptions
Use the data in the following table to use theInterfaces tab.
                                 Name  |
                                 Description  |
                                 Index  |
                                 Specifies the identifier of the circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value.  |
                                 IfIndex  |
                                 Specifies the interface on which the circuit is configured (port or MLT).  |
                                 Type  |
                                 Specifies the IS-IS circuit type. Only the point-to-point (PtToPt) interface type is supported.  |
                                 AdminState  |
                                 Specifies the administrative state of the circuit: on or off.  |
                                 OperState  |
                                 Specifies the operational state of the circuit.  |
                                 AuthType  |
                                 Specifies the authentication type:
 The default is none.  |
                                 AuthKey  |
                                 Specifies the authentication key.  |
                                 KeyId  |
                                 Specifies the authentication key ID.  |
                                 LevelType  |
                                 Specifies the router type globally:
 The default value is level1.  |
                                 NumAdj  |
                                 Specifies the number of adjacencies on this circuit.  |
                                 NumUpAdj  |
                                 Specifies the number of adjacencies that are up.  |
                                 AutoNniEnable  |
                                 Enable to have the node create an IS-IS interface, attach the interface to an SPBM instance, and then enable IS-IS on the port interface. This field displays on the Insert Interfaces dialog box and applies to port interfaces only.  |
| Origin |
                                 Specifies the origin of the IS-IS circuit configuration on the port, either manually configured through CLI or EDM or dynamically configured through Auto-sense.  |
