This procedure only applies to the VSP 7400 Series.
  • Enable multicast on the boundary nodes.
  • Configure Multicast Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
Perform this procedure to configure Multi-area SPB IPv4 static I-SID routed multicast redistribution on the switch.
  • Routed multicast redistribution is available for IPv4 only.
  • Multi-area SPB boundary nodes can redistribute static data I-SIDs, and the static data I-SID multicast redistribution policy takes precedence over the Layer 2 multicast redistribution.
  • Multi-area SPB boundary nodes with remote IS-IS enabled do not support IP SPB Multicast Policy .
  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Configure the Multi-area SPB IPv4 static I-SID list to redistribute on the switch:
    multi-area ip redistribute static-isid-routed-multicast [home-to-remote | remote-to-home] isid-list WORD<1-32>
    The system displays the warning message while configuring the Multi-area SPB IPv4 static I-SID routed multicast redistribution:
    WARNING: L3 static i-sid routed multicast will not be inter-area redistributed until apply command is issued after enable command.
  3. Enable the Multi-area SPB IPv4 static I-SID routed multicast redistribution instance:
    multi-area ip redistribute static-isid-routed-multicast [home-to-remote | remote-to-home] enable
  4. Verify the Multi-area SPB IPv4 static I-SID routed multicast redistribution configuration:
    show isis multi-area ip redistribute static-isid-routed-multicast [home-to-remote | remote-to-home]
  5. Apply the Multi-area SPB IPv4 static I-SID routed multicast redistribution:
    isis multi-area ip apply redistribute static-isid-routed-multicast
Configuring Multi-area SPB IPv4 static I-SID list to redistribute for remote to home direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ip redistribute static-isid-routed-multicast remote-to-home isid-list list2
Switch:1(config-isis)#multi-area ip redistribute static-isid-routed-multicast [home-toremote | remote-to-home] enable
Switch:1(config-isis)#show isis multi-area ip redistribute static-isid-routed-multicast remote-to-home
      MULTI-AREA IP REDISTRIBUTE STATIC ISID ROUTED MULTICAST - ALL VRF
DIRECTION            ENABLE     ISID LIST
remote-to-home 	 TRUE        list2
Switch:1(config-isis)#isis multi-area ip apply redistribute static-isid-routed-multicast
