Use this procedure to view Fabric Attach discovered elements.
When FA is enabled on an FA Server switch, LLDP PDUs are exchanged between the FA Server and FA Clients or FA Proxies. Standard LLDPs allow neighbors to be learned. With the help of organizational-specific element discovery TLVs, the client or proxy recognizes that it has attached to the FA Server. Only after the discovery handshake is complete, an FA Client or FA Proxy can transmit I-SID-to-VLAN assignments to join the SPB Fabric network through the FA Server.
The following example displays the sample output for the show fa elements command.
Switch:1#show fa elements
                        Fabric Attach Discovery Elements
                         MGMT                                         ELEM ASGN
PORT   TYPE              VLAN STATE  SYSTEM ID                        AUTH AUTH
1/5    proxy             710  T / S  50:61:84:ee:8c:00:20:00:00:01    AP   AP
1/6    proxy             710  T / S  50:61:84:ee:8c:00:20:00:00:01    AP   AP
                      Fabric Attach Authentication Detail
       ELEM OPER                      ASGN OPER
PORT   AUTH STATUS                    AUTH STATUS
1/5    successAuth                    successAuth
1/6    successAuth                    successAuth
State Legend: (Tagging/AutoConfig)
T= Tagged,    U= Untagged,    D= Disabled,    S= Spbm,    V= Vlan,    I= Invalid
Auth Legend:
AP= Authentication Pass,  AF= Authentication Fail,
NA= Not Authenticated,  N= None
2 out of 2 Total Num of fabric attach discovery elements displayed
Variable definitions
The following table defines parameters for the show fa elements command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
