View the RSMLT peers for which the switch acts as a peer forwarder.
 - Select RSMLT.
 - Select the Edge Peers tab.
Edge Peers field descriptions
Use the data in the following table to use the Edge Peers tab.
Name  | Description  |
PeerVlanId  | Specifies the ID of the VLAN associated with this entry.  |
PeerIpv6Address  | Specifies the IPv6 address of the peer RSMLT interface.  |
PeerIpv6PrefixLength  | Specifies the peer IPv6 address prefix.  |
PeerMacAddress  | Specifies the peer MAC address.  |
