Use the following procedure to generate the private and public key pair. By default, VOSS generates a 2,048 RSA key when the system starts. You can use this procedure to generate a new key.
Configure an EJBCA CA server.
Configure a route from Fabric IPsec Gateway to the EJBCA CA server.
Switch:1>enable Switch:1#virtual-service FIGW console FIGW>certificate generate key rsa 2048 key_rsa fingerprint: 09ac0c64b9bf3ad04dc67f20942c674e
The following table defines parameters for the certificate generate key command.
| Variable | Value |
                                 key-label  |
                                 Specifies the key name of the generated key pair.  |
                                 size  |
                                 Specifies the size of key-pair to be generated. The switch supports 2048.  |
                                 type  |
                                 Specifies the type of cryptography algorithm used to generate the key-pair. The switch uses only rsa as the cryptography algorithm type.  |
