Perform this procedure to uninstall a configured virtual service.
If a virtual machine is running, it is stopped, and then the service directory is uninstalled.
You must disable the virtual service before you uninstall it.
Switch:1>enable Switch:1#virtual-service tpvm uninstall
Use data in the following table to use the virtual-service command.
                             Variable  |
                             Value  |
                             WORD<1-128>  |
                             Specifies the virtual service name.  |
                             uninstall  |
                             Uninstalls the specified virtual service name.  |
