This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB layer 2 I-SID list.
Configuring the Multi-area SPB layer 2 I-SID list that includes specific I-SID values:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#multi-area l2 isid-list testlist 1,3,5,100-200
What to do next
To verify the configuration, see Display IS-IS Multi-area SPB Layer 2 I-SID List Information.
The following table defines parameters for the multi-area l2 isid-list command.
| Variable | Value |
| WORD<1-32> |
                                 Specifies the name of the I-SID list.  |
| WORD<1-1024> |
                                 Specifies the list of I-SID values.  |
