You manage UDP forwarding by defining the destination addresses for the UDP protocol.
Forwardings field descriptions
Use the data in the following table to use the Forwardings tab.
 Name  |
 Description  |
 DestPort  |
 Specifies the port number defined for UDP, depending upon the protocol type.  |
 DestAddr  |
 Specifies the destination address can be any IP server address for the protocol application or the IP address of an interface on the router:
 Id  |
 Specifies an integer that identifies this entry internally.  |
 NumFwdPackets  |
 Specifies the total number of UDP broadcast packets forwarded using this policy.  |
 NumDropPacketsTtlExpired  |
 Specifies the total number of UDP broadcast packets dropped because the time-to-live value (TTL) expired.  |
 NumDropPacketsDestUnreach  |
 Specifies the total number of UDP broadcast packets dropped because the specified destination address was unreachable.  |
