Configure redistribute entries for BGP to announce routes of a certain source type to BGP, for example, DvR, direct, static, Routing Information Protocol (RIP), and Open Shortest Path First (OSPF). If you do not configure a route policy, then the switch uses the default action based on metric, metric type, and subnet. Use a route policy to perform detailed redistribution.
If required, configure a route policy.
When you configure BGP on a specific VRF instance, the VRF must have an RP trigger of BGP.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
 Before you redistribute DvR host routes to BGP, ensure that you disable BGP aggregation and BGP auto-summarization of networks. Disabling these options ensures that all DvR host routes are advertised into BGP correctly, and are not summarized.
 - Select BGP.
 - Select the Redistribute tab.
 - Select Insert.
 - Configure the source protocol.
 - Optional: If required, choose a route policy.
 - Configure the metric to apply to redistributed routes.
 - Enable the redistribution instance.
 - Select Insert.
Redistribute field descriptions
Use the data in the following table to use the Redistribute tab.
 Name  |
 Description  |
 DstVrfId  |
 Specifies the destination VRF instance (read-only).  |
 Protocol  |
 Specifies the protocols that receive the redistributed routes.  |
 SrcVrfId  |
 Specifies the source VRF instance (read-only).  |
 RouteSource  |
 Specifies the source protocol for the route redistribution entry.  |
 Enable  |
 Enables (or disables) a BGP redistribute entry for a specified source type.  |
 RoutePolicy  |
 Configures the route policy to use for the detailed redistribution of external routes from a specified source into the BGP domain.  |
 Metric  |
 Configures the metric for the redistributed route. The value can be a range between 0–65535. The default value is 0. Use a value that is consistent with the destination protocol.  |
