Configuring an ACE IP DSCP
Configure ACE IP DSCP entries to have the filter look for packets with specific DSCP markings.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click IP.
 - Click the DSCP tab.
 - Click Insert.
 - Specify the operation type.
 - In the List box, enter the count for the DSCP values.
 - Click Insert.
DSCP field descriptions
Use the data in the following table to use the DSCP tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 List  |
 Specifies a count for the number of discrete ranges entered for the DSCP values. Entries include 0–256, disable, phbcs0, phbcs1, phbaf11, phbaf12, phbaf13, phbcs2, phbaf21, phbaf22, phbaf23, phbcs3, phbaf31, phbaf32, phbaf33, phbcs4, phbaf41, phbaf42, phbaf43, phbcs5, phbef, phbcs6, and phbcs7.  |
 OperMask  |
 Specifies the mask value.  |
