Use IPv6 prefix lists to allow or deny specific IPv6 route updates. A prefix list policy specifies route prefixes to match. When there is a match, the route is used.
You configure prefix lists on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode.
Create an IPv6 prefix list:
Switch:1<config>#ipv6 prefix-list list4 2001:DB8::/32 ge 32 le 32
To rename the list:
Switch:1<config>#ipv6 prefix-list list4 name list5
Use the data in the following table to use the ipv6 prefix-list command.
                             Variable  |
                             Value  |
                             <WORD 1–64>  |
                             Specifies the IPv6 prefix-list name.  |
                             <WORD 1–256>  |
                             Specifies the IPv6 prefix and length.  |
                             ge <0–128>  |
                             Specifies the minimum length to match. Lower bound and higher bound mask lengths together can define a range of networks.  |
                             id <1-2147483647>  |
                             Specifies the Prefix list ID.  |
                             le <0–128>  |
                             Specifies the maximum length to match. Lower bound and higher bound mask lengths together can define a range of networks.  |
                             name <WORD 1–64>  |
                             Names the prefix list. The default value is none.  |
Use the data in the following table to use the show ipv6 prefix-list command.
                             Variable  |
                             Value  |
                             <WORD 1–256>  |
                             vrf WORD<1-16>  |
                             Specifies the name of the VRF.  |
                             vrfids WORD<0-512>  |
                             Specifies the ID of the VRF and is an integer in the range of 0–512.  |
                             WORD<1-64>  |
                             Specifies a prefix list, by name, to use for the command output.  |
