Use the forwarding database for VLANs to determine how the system forwards a received frame.
- In the navigation tree, expand the following folders:
 - Click VLANs.
 - Select a VLAN.
 - Click Bridge.
 - Click the Forwarding tab and the VLAN forwarding database information is displayed.
Forwarding Field Descriptions
Use the data in the following table to use the Forwarding tab.
 Name  |
 Description  |
 VlanId  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 Address  |
 Specifies a unicast MAC address for which the bridge has forwarding or filtering information.  |
 Status  |
 Specifies the status. Values include the following:
 Port  |
 Specifies either a value of zero (0) or the port number of the port on which a frame having the specified MAC address was seen. A value of cpp indicates a self-assigned MAC address.  |
 Cvid  |
 Identifies the customer VID for this interface.  |
