This procedure does not apply to VSP 8600 Series.
Use this task to view TCP connections and UDP endpoints statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IP/IPv6 Socket (TCP/UDP) tab.
IP/IPv6 Socket (TCP/UDP) Field Descriptions
Use the data in the following table to use the IP/IPv6 Socket (TCP/UDP) tab.
 Name  |
 Description  |
 IPVersion  |
 Shows the IP address version as ipv4 or ipv6.  |
 Type  |
 Shows the connection type as tcp or udp.  |
 Index  |
 Shows the index ID for the connection.  |
 State  |
 Shows the link state for the connection.  |
                 RecvQ  |
                 Shows the connection received quanitity.  |
| SendQ |
                 Shows the connection sent quantity.  |
| LocalAddressAndPort |
                 Shows the local IP address and port.  |
| PeerAddressAndPort |
                 Shows the peer IP address and port.  |
