The switch authorizes ports by default, which means that the ports are always authorized and are not authenticated by the RADIUS server.
You can also make the ports controlled so that they are dependent on being authorized by the Radius Server when you globally enable EAP (auto).
Configure the authorization status of a port:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 3/1 Switch:1(config-if)#eapol status auto
The following table defines parameters for the eapol status command.
                             Variable  |
                             Value  |
                             authorized  |
                             Specifies that the port is always authorized. The default value is authorized.  |
                             auto  |
                             Specifies that port authorization depends on the results of the EAP authentication by the RADIUS server. The default value is authorized.  |
