Use this procedure to determine the protocol configured on the added VLAN.
The protocol configured on the added VLAN can be one of the following values:
  • snoop
  • snoop-spb
  • route-spb
  • pim
  1. Enter Privileged EXEC mode:
    enable
  2. Determine the protocol configured on the added VLAN:
    show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>][vrf WORD<1–16>] [vrfids WORD<0–512>]
    The protocol displays under the Mode column of the command output.
Switch:1#show ip igmp interface
                         Igmp Interface - GlobalRouter
       QUERY              OPER           QUERY   WRONG              LASTMEM                     SCOPE
IF     INTVL STATUS VERS. VERS QUERIER   MAXRSPT QUERY JOINS ROBUST QUERY   MODE       L2ISID   ISID
V100   125    activ  2     2   0.0.0.0    100     0     0     2      10      snoop-spb 1100
1 out of 1 entries displayed
The following table defines parameters for the show ip igmp interface command.
Variable
Value
gigabitethernet{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
vlan<1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
vrfWORD<1–16>
Specifies the VRF instance by the VRF name.
vrfidsWORD<0–512>
Specifies the VRF ID for which to display statistics.
