You can modify the ingress mappings to change traffic priorities. However, as a best practice, use the default mappings.
Use the data in the following table to use the qos ingressmap command.
                             Variable  |
                             Value  |
                             1p <0-7> <0-6>  |
                             Maps the IEEE 802.1p bit to QoS level. Each QoS level has a default
                                IEEE 1P value:
 default qos ingressmap 1p  |
                             ds <0-63> <0-6>  |
                             Maps the DS byte to QoS level. The system reserves level 7 for Network Control. To use the default configuration, use the default option in the command: default qos ingressmap ds  |
