View power information to see the amount of power available and used by the chassis and all components.
- On the Device Physical View, select the Device.
 - Select Chassis.
 - Select the Power Info tab.
Power Info field descriptions
Use the data in the following table to use the Power Info tab.
 Name  |
 Description  |
 TotalPower  |
 Shows the total power for the chassis.  |
 RedundantPower  |
 Shows the redundant power for the chassis.  |
 PowerUsage  |
 Shows the power currently used by the complete chassis.  |
 PowerAvailable  |
 Shows the unused power.  |
