This procedure does not apply to XA1400 Series.
Use this procedure to configure the Layer 2 tracemroute on the VRF (Layer 3). This procedure queries the SPBM multicast module to determine the B-VLAN, I-SID and nickname for the S and G streams. The nickname and I-SID are used to create a multicast MAC address.
If you want to run a Layer 2 tracemroute on a VRF, make sure you are in the proper VRF context.
To perform a Layer 3 tracemroute on a VLAN, see Configure Layer 2 Trace Multicast Route on a VLAN.
On the source and destination nodes, you must configure a CFM MD, MA, and MEP, and assign a nodal MEP to the B-VLAN.
 - Select a VRF, and then select the Launch VRF Context View tab.
 - Select the tab.
 - Select .
 - Type the .
 - Type the .
 - Select the . If you want to perform a Layer 2 tracemroute on a Layer 2 VRF, select vlan. If you want to perform a Layer 2 tracemroute on a Layer 3 VRF, select vrfid.
 - In the ServiceId, type the VLAN ID.
 - Type the .
 - Type the value.
 - Select .
 - Select to save your changes.
 - To start the Layer 2 tracemoute, configure the Status to transmit, and then select Start.
 - To update the Layer 2 tracemroute, select Refresh .
 - To stop the Layer 2 tracemroute, select Stop .
 - To see the result, select Result.
L2 MCAST Traceroute Field Descriptions
Use the data in the following table to use the L2 MCAST Traceroute tab.
 Name  |
 Description  |
 SrcIpAddrType  |
 Specifies the source IP address type as IPv4.  |
 SrcIpAddr  |
 Specifies the source IP address of the flow where the multicast trace tree originates.  |
 GroupIpAddrType  |
 Specifies the group IP address type as IPv4.  |
 GroupIpAddr  |
 Specifies the group IP address.  |
 ServiceType  |
 Specifies where you configure the Layer 2 tracemroute. This is either VLAN or VRF.  |
 ServiceId  |
 Specifies the VLAN ID.  |
 VRFName  |
 Specifies the VRF name.  |
 Priority  |
 Specifies the priority value. The value is between 0 and 7.  |
 Ttl  |
 Specifies the returned trace response. The TTL value is between 1 and 255.  |
 SeqNumber  |
 Specifies the transaction identifier/sequence number of the first message to be sent.  |
 Status  |
 Specifies the status of the transmit loopback service:
 The column will also be used to avoid concurrency or race condition problems that can occur if two or more management entities try to use the service at the same time.  |
 ResultOK  |
 Specifies the result of the operation:
 Flag  |
 Specifies the result flag indicating that the Layer 2 trace status or error code. Each value
                                    represents a status or error case.
