Use the following procedure to configure an aging interval for IPFIX. The aging interval determines how long a traffic flow that is no longer being received, is retained as a flow.
        Enter Global Configuration mode:
        enable
configure terminal
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix aging-interval 30
The following table defines parameters for the ip ipfix aging-interval command.
                             Variable  |
                             Value  |
                             <1-60>  |
                             Specifies (in seconds) the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow. The default is 40 seconds.  |
