Table 1. MACsec product support
Feature
Product
Release introduced
MACsec 2AN mode (static)
Note:
VOSS 5.0 officially removed the replay protection commands. Do not use replay protection in earlier releases.
VSP 4450 Series
VSP 4000 4.0
VSP 4900 Series
VOSS 8.5
VSP 7200 Series
VOSS 4.2.1
VSP 7254XTQ only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 4.1
VSP 8400 Series
VOSS 4.2
VSP 8600 Series
Not Supported
XA1400 Series
Not Supported
MACsec 4AN mode (static)
VSP 4450 Series
VOSS 6.0
VSP 4900 Series
VOSS 8.1
VSP 7200 Series
VOSS 6.0
VSP 7254XTQ only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 6.0
VSP 8400 Series
VOSS 6.0
VSP 8600 Series
VSP 8600 4.5
XA1400 Series
Not Supported
MACsec encryption cipher suites
VSP 4450 Series
VOSS 8.1
128 bits only
VSP 4900 Series
VOSS 8.1
  • VSP4900-48P supports 128-bit on all fixed ports.
  • VSP4900-24XE supports 128-bit and 256-bit on all fixed ports.
  • VSP4900-12MXU-12XE supports 128-bit and 256-bit on the SFP+ ports.
  • VIM5-4XE and VIM5-4YE supports 128-bit and 256-bit cipher suite.
VSP 7200 Series
VOSS 8.1
128 bits only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 8.1
128 bits only
VSP 8400 Series
VOSS 8.1
128 bits only
VSP 8600 Series
VSP 8600 6.2
8624XS supports 128 bits only. 8606CQ supports 128 bits and 256 bits.
XA1400 Series
Not Supported
MACsec Key Agreement (MKA)
VSP 4450 Series
Not Supported
VSP 4900 Series
VOSS 8.5
VSP 7200 Series
Not Supported
VSP 7400 Series
Not Supported
VSP 8200 Series
Not Supported
VSP 8400 Series
VOSS 8.1
VSP 8600 Series
VSP 8600 8.1
XA1400 Series
Not Supported
