Use this procedure to provide a descriptive name for the Service Identifier (I-SID).
Product Notice: This procedure does not apply to VSP 8600 Series.
You can configure a service name for I-SIDs, loopback interfaces, and static routes. You can configure the service name can before or after you create the I-SID for the following services:
- Layer 2 VSN
 - Layer 3 VSN
 - ELAN I-SID or Switched UNI I-SID
 - ELAN transparent I-SID or Transparent UNI I-SID
 - IPv4 and IPv6 static routes
 - IPv4 and IPv6 loopback CLIP interface
The service name for I-SIDs does not support the following special characters: “ ” # $ % ‘ / [ \ ] ^ { | } ~ @.
By default, the service name is ISID-x, where x correlates to the I-SID number of the service.
Product Notice: For XA1400 Series, you can configure a service name for IPv4 static routes and IPv4 loopback CLIP interfaces only.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#i-sid name 1 ExtremeServer1 Switch:1(config)#i-sid name 20 ExtremeServer7
View the configured I-SID names:
Switch:1(config)#show i-sid name
                          I-SID Name
I-SID           I-SID NAME                      TYPE
1               ExtremeServer1                  adminName
2               ExtremeServer2                  adminName
3               ExtremeServer3                  config adminName
4               ISID-4                          config
23              ISID-23                         config
25              ExtremeServer4                  config adminName
Total number of I-SID Name entries: 6.
            View the configured I-SID by number:
Switch:1#show i-sid name 1=======================================================================I-SID Name=======================================================================I-SID I-SID NAME TYPE-----------------------------------------------------------------------1 ExtremeServer1 adminName
Switch:1#show i-sid name 20=======================================================================I-SID Name=======================================================================I-SID I-SID NAME TYPE-----------------------------------------------------------------------20 ExtremeServer7 adminName
Use the data in the following table to use the i-sid name command.
                             Variable  |
                             Value  |
| <1-6777215> |
                             Specifies the I-SID number.  |
| WORD<1-64> Note:
This parameter does not apply to all hardware platforms.  |
                             Specifies the name of the I-SID. The I-SID can be named before or after the I-SID is created. By default, for an I-SID in use, the service is named ISID-x, where x correlates to the I-SID number of the service.  |
