The following table defines parameters for the multi-area ip redistribute static-isid-routed-multicast command.
                                 Variable  |
                                 Value  |
                                 enable  |
                                 Enables Multi-area SPB IPv4 static I-SID routed multicast redistribution.  |
                                 home-to-remote  |
                                 Specifies the IPv4 static I-SID routed multicast redistribution configuration for home to remote direction.  |
                                 isid-listWORD<1-32>  |
                                 Specifies the name of the I-SID list.  |
                                 remote-to-home  |
                                 Specifies the IPv4 static I-SID routed multicast redistribution configuration for remote to home direction.  |
