This procedure only applies to XA1400 Series.Configure IPsec fragmentation before encryption to avoid possible throughput penalty for sending fragmented packets over the Internet.
Configure the IPsec tunnel source address globally.
Disable IPsec on the logical interface.
IPsec over Fabric Extend must be in IPsec decoupled mode. For more information, see Fabric IPsec Gateway Fundamentals.
Configure one of the following:
the IPsec tunnel destination IP
IPsec NAT-T responder only mode
IPsec responder remote NAT IP address
enable
configure terminal
logical-intf isis <1–255>
Enable IPsec fragment before encryption and verify the configuration:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#logical-intf isis 2 Switch:1(config-isis-2-192.0.2.24)#ipsec fragment-before-encrypt Switch:1(config-isis-2-192.0.2.24)#ipsec
Switch:1>show isis logical-interface ipsec
                          ISIS Logical Interface IPSec
ID   Status   Auth-Method   Auth-Key  ESP                  Responder-Only   Remote NAT IP  Auth-Key-Len Compression Frag-before-encrypt
1    Enable   RSA-SIG       ******    aes128gcm16-sha256   False            -              128          False       True
 1 out of 1 Total Num of Logical ISIS interfaces
                           IPSec Tunnel General Info
       IPSec tunnel global source-ip-address : 203.0.113.1
                               ISIS IPSec Tunnels
ID    IPSec source    IP            IPSec Dst Ip        TUNNEL_NEXT_HOP
      type            address                           PORT/MLT   VLAN        VRF
1     global          203.0.113.1   100.100.100.6      Port1/6    100       GlobalRouter
