Use the following procedure to view content of a USB file.
Caution
Always use the usb-stop command to safely unplug the USB drive from the USB slot.
Switch:1#enable
Switch:1#more /usb/test.cfg
Variable definitions
The following table defines parameters for the more command.
 Variable  |
 Value  |
 WORD<1–99>  |
 Specifies the file name in the following format:
 The file name, including the directory structure, can include up to 99 characters.  |
