Clear the SA cache to clear the SA entries the router learns from all the peers or a specific peer.
 - Click MSDP.
 - Click the SA-Cache tab.
 - Click Clear SA-Cache.
SA-Cache field descriptions
Use the data in the following table to use the SA-Cache tab.
 Name  |
 Description  |
 GroupAddr  |
 Shows the group IP address of the SA cache entry.  |
 SourceAddr  |
 Shows the source IP address of the SA cache entry.  |
 OriginRP  |
 Shows the RP address of the SA cache entry.  |
 PeerLearnedFrom  |
 Shows the peer from which this SA cache entry was accepted.  |
 RPFPeer  |
 Shows the peer from which an SA message corresponding to the cache entry is accepted.  |
 InSAs  |
 Discontinuities in the value of this counter can occur at reinitialization of the management system.  |
 InDataPackets  |
 Shows the number of MSDP encapsulated data packets received that are relevant to this cache entry.  |
 UpTime  |
 Shows the time since this entry was first placed in the SA cache.  |
 ExpiryTime  |
 Shows the time remaining before this entry expires from the SA cache.  |
