Force the switch to update its shortest-path calculations so that the switch uses the latest OSPF routing information. Manually initiate a shortest path first (SPF) run, or calculation, to immediately update the OSPF LSDB. This action is useful in the following circumstances:
when you need to immediately restore a deleted OSPF-learned route
when the routing table entries and the LSDB do not synchronize
You can perform this procedure in one of the following CLI modes: User EXEC, Privileged EXEC, or Global Configuration.
This process is computationally intensive. Use this command only if required.
Force the router to update its shortest-path calculations:
Switch:1>ip ospf spf-run
Variable definitions
The following table defines parameters for the ip ospf spf-run command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF instance by name.  |
