This procedure does not apply to VSP 8600 Series and XA1400 Series.
Enable Auto-sense on the port.
Associate a VLAN with the I-SID before you configure it as the data I-SID on the port. This does not apply to a DvR leaf.
This option applies to the Auto-sense UNI and voice states only, it replaces the onboarding I-SID and places an (untagged) client device into a pre-defined port specific data I-SID.
Configuring the Auto-sense data I-SID for ports 1/1 to 1/5:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1-1/5 Switch:1(config-if)#auto-sense data i-sid 15000000
The following table defines parameters for the auto-sense data command.
Variable |
Value |
i-sid <1-15999999> |
Specifies the service instance identifier (I-SID). |
