To configure the switch as CDP-compatible, you must enable the Industry Standard Discovery Protocol (ISDP) on a port, or ports, on the switch. To enable ISDP, you use the lldp cdp command.
If CDP is enabled, the interface accepts only CDP packets. Similarly, if CDP is disabled but LLDP is enabled, the interface accepts only LLDP packets.
To switch a port from CDP mode to LLDP mode, the LLDP status on that port must be txAndrx.
Do not enable CDP mode if you plan to use the port with an ONA or Fabric Attach.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. To enable CDP, enter the following command:
    lldp cdp enable
  3. Optional: To disable CDP, enter the following command:
    no lldp cdp enable
To enable CDP on a port:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface GigabitEthernet 4/4
Switch:1(config-if)#lldp cdp enable
To switch a port from CDP mode to LLDP mode, LLDP status on that port must be txAndrx.
Switch:1>enable
Switch:1(config-if)#no lldp cdp enable
To shutdown LLDP or CDP on a port:
Switch:1>enable
Switch:1>(config-if)#no lldp status
