The default Auto-Negotiation behavior depends on the switch model, port type, and transceiver type. The following table provides the default combinations.
Table 1. VSP 4900 Series default behavior
Model
Port type
Transceiver type
FEC
VSP4900-48P
1GBASE-T
Enabled
VSP4900-24S
SFP
100BASE-FX
1GBASE-T
Enabled
1G SFP
Enabled
VSP4900-24XE
SFP+
100BASE-FX
1GBASE-T
Enabled
The operational state is always enabled regardless of configuration.
1G SFP
Disabled
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
VSP4900-12MXU-12XE
100M/1/2.5/5/10Gbps Copper
Enabled
SFP+
100BASE-FX
1GBASE-T
Enabled
1G SFP
Disabled
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
VIM5-4X
SFP+
1GBASE-T
Not Supported
1G SFP
Disabled
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
VIM5-4XE
SFP+
1GBASE-T
Enabled
1G SFP
Disabled
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
VIM5-2Y and VIM5-4Y
SFP28
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
25G DAC
Disabled
Not Supported
25G AOC
Not Supported
25G SFP28
Not Supported
VIM5-4YE
SFP28
10GBASE-T
Enabled
10G DAC
Disabled
10G SFP+
25G DAC
Enabled
FEC is negotiated requesting CL108.
25G AOC
FEC auto: CL108
25G SFP28
FEC auto: CL108
