Configure individual system-level switch parameters to configure global options for the switch.
Switch:1> enable
Switch:1# configure terminal
Configure the system, or root level, prompt name for the switch:
Switch:1(config)# sys name Floor3Lab2
The following table defines parameters for the sys command.
                 Variable  |
                 Value  |
                  clipId-topology-ip
              Note:
Exception: Only supported on VSP 8600 Series  |
                 Configures the topology ip from the available CLIP. WORD<1-256>specifies the Circuitless IP interface id.  |
                 control tcp-timestamp  |
                 Enables or disables TCP Timestamp.  |
                 force-msg  |
                 Adds forced message control pattern. WORD<4–4> Enter force message pattern.  |
                  force-topology-ip-flag
              Note:
                 Flags set to force choice of topology flag. enable  |
                 msg-control  |
                 Configures system message control feature.  |
                 mtu <1522-9600>  |
                 Configures Jumbo frame support for the data path. The value can be either 1522, 1950 (default), or 9600 bytes.  |
                 name WORD<0–255>  |
                 Configures the system, or root level, prompt name for the switch. WORD<0–255> is an ASCII string from 0–255 characters (for example, LabSC7 or Closet4).  |
                 power  |
                 Enables power to specified slot(s).  |
                 security-console  |
                 Enables the security console.  |
                 software  |
                 Configures software configuration.  |
                 priv-exec-password  |
                 Enables authentication for the Privileged EXEC CLI command mode.  |
