- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click the Ssm Globals tab.
Ssm Globals field description
Use the data in the following table to use the Ssm Globals tab.
 Field  |
 Description  |
 RangeGroup  |
 Specifies the ssm range.  |
 RangeMask  |
 Specifies the ssm range mask.  |
