This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure remote SPBM global parameters. SPBM uses the remote Intermediate-System-to-Intermediate-System (IS-IS) link state routing protocol to provide a loop free Ethernet topology that creates a shortest path topology from every node to every other node in the network based on node MAC addresses.
 - Select SPBM Remote.
 - Select the SPBM tab.
 - Select Insert to create a remote SPBM instance.
 - Configure the remote SPBM parameters.
 - Select Insert.
SPBM Field Descriptions
Use data in the following table to use the SPBM tab.
 Name  |
 Description  |
 Id  |
 Specifies the remote SPBM instance ID.  |
 NodeNickName  |
 Specifies a nickname for the remote SPBM instance globally. The value is 2.5 bytes in the format <x.xx.xx>.  |
 PrimaryVlan  |
 Specifies the primary SPBM B-VLANs to add to the remote SPBM instance.  |
 Vlans  |
 Specifies the SPBM B-VLANs to add to the remote SPBM instance.  |
 LsdbTrap  |
 Enables or disables a trap when the SPBM LSDB changes. The default is disable.  |
 IpShortcut  |
 Enables or disables SPBM IP shortcut state. The default is disable.  |
 SmltSplitBEB  |
 Specifies whether the switch is the primary or secondary vIST peer. The default is primary.  |
 SmltVirtualBmac  |
 Specifies a virtual MAC address that can be used by both peers.  |
 SmltPeerSysId  |
 Specifies the system ID of the SPBM SMLT for this remote SPBM instance.  |
 Mcast  |
 Specifies if IP multicast over remote SPBM is enabled. The default is disabled.  |
 McastFwdCacheTimeout  |
 Specifies the global forward cache timeout in seconds. The default is 210 seconds.  |
 Ipv6Shortcut  |
 Enables or disables SPBM IPv6 shortcut state. The default is disable.  |
 McastSpbPimGwControllerEnable  |
 Enables or disables ISIS PLSB Multicast SPB PIM Gateway controller. Disabled by default.  |
 McastSpbPimGwGatewayEnable  |
 Enables or disables ISIS PLSB Multicast SPB PIM Gateway. Disabled by default.  |
 StpMultiHoming  |
 Enables or disables MSTP-Fabric Connect Multi Homing. The default is disabled (false).  |
                                                   BVlanOrigin  |
                                                   Specifies the origin of the B-VLAN. The values are:
 The default is dynamic.  |
