Run a Ping Test
Use ping to determine if an entity is reachable.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
  1. From the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Click Ping/Trace Route.
  3. Click the Ping Control tab.
  4. Click Insert.
  5. In the OwnerIndex box, type the owner index.
  6. In the TestName box, type the name of the test.
  7. In the TargetAddress box, type the host IP address.
  8. From the AdminStatus options, select enabled.
  9. In the remainder of the option boxes, type the desired values.
  10. Click Insert.
  11. Select and entry, and then click Start.
    Let the test run for several seconds.
  12. Select an entry, and then click Stop.
  13. View the Ping results.
Ping Control Field Descriptions
Use the data in the following table to use the Ping Control tab.
Name
Description
OwnerIndex
Provides access control by a security administrator using the View-Based Access Control Model (VACM) for tables in which multiple users need to independently create or modify entries. This is a string of up to 32 characters.
TestName
Specifies the name of the ping test.
TargetAddress
Specifies the host address to use at a remote host to perform a ping operation.
DataSize
Specifies the size of the data portion (in octets) to transmit in a ping operation. The default is 16.
TimeOut
Specifies the timeout value, in seconds, for a remote ping operation. The default is 3 seconds.
ProbeCount
Specifies the number of times to perform a ping operation at a remote host. The default is 1.
AdminStatus
Specifies the state of the ping control entry: enabled or disabled. The default is disabled.
DataFill
Determines the data portion of a probe packet.
Frequency
Specifies the number of seconds to wait before repeating a ping test. The default is 0.
MaxRows
Specifies the maximum number of entries allowed in the PingProbeHistory table. The default is 50.
TrapGeneration
Specifies when to generate a notification. The options are:
  • ProbeFailure—Generates a PingProbeFailed notification subject to the value of TrapProbeFailureFilter. The object TrapProbeFailureFilter can specify the number of successive probe failures that are required before a pingProbeFailed notification is generated.
  • TestFailure—Generates a PingTestFailed notification. The object TrapTestFailureFilter can determine the number of probe failures that signal when a test fails.
  • TestCompletion—Generates a PingTestCompleted notification.
The value of this object defaults to zero, indicating that none of the above options have been selected.
Specifies the number of successive probe failures that are required before a pingProbeFailed notification is generated. The default is 1.
Determines the number of probe failures that signal when a test fails. The default is 1.
Descr
Describes the remote ping test. The default is 0x00.
SourceAddress
Specifies the IP address (a.b.c.d) as the source address in outgoing probe packets.
ByPassRouteTable
Enables (optionally) the bypassing of the route table. The default is disabled.
