Configuring a node as a DvR isolated Controller enables DvR globally on that node.
  • Ensure that you configure IP Shortcuts on the node.
  • Ensure that the dvr-leaf-mode boot flag is disabled on the node.
    To verify the configuration, enter show boot config flags in Privileged EXEC mode.
Perform this procedure to create a DvR isolated domain with the domain ID that you specify, and configure the role of the node as an isolated Controller of that domain. For more information about the DvR isolated domain and Restrictions on a DvR Isolated Controller, see DvR Isolated Domains and Restrictions on a DvR Isolated Controller.
Disabling DvR on a DvR Controller destroys the domain ID and all dynamic content learned within the DvR domain. However, the switch retains the VLAN specific configuration and you can view the information using the command show running-config.
    enable
    configure terminal
  2. Configure an isolated DvR domain ID:
    dvr isolated controller <1-255>
  3. Optional: Disable default route injection for the GRT on an isolated Controller:
    dvr isolated controller <1-255> inject-default-route-disable
  4. View a summary of the Controller configuration:
    show dvr
Configure a node as a DvR Controller for an isolated domain:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#dvr isolated controller 34
Switch:1>show dvr
                        DVR Summary Info
Domain ID                      : 34
Domain ISID                    : 16678250
Backbone                       : isolated
Role                           : Controller
My SYS ID                      : e4:5d:52:3c:64:84
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
InjectDefaultRouteDisable(GRT) : Disabled
VRRP on DVR I-SIDs             : Disabled
VRRP Priority                  : 100
VRRP Election                  :
Disable injection of default routes for the GRT on an isolated Controller.
Switch:1>enable
Switch:1(config)#dvr isolated controller 34 inject-default-route-disable
Switch:1(config)#show dvr
                          DVR Summary Info
Domain ID                      : 34
Backbone                       : isolated
Role                           : Controller
InjectDefaultRouteDisable(GRT) : Enabled
VRRP Priority                  : 100
VRRP Election                  :
