This procedure does not apply to XA1400 Series and VSP 8600 Series.
Configure Multicast Label Switching Virtual Private Network (MVPN) on VRF.
Enable IP Multicast over Fabric Connect globally.
Configure IP prefix list in GRT/VRF.
Perform this procedure to create the IP SPB Multicast Policy globally.
You can also configure the IP SPB Multicast Policy on a VRF instance in the same way as you configure on the GlobalRouter, except that you must use the VRF Router Configuration mode and create the route-map in VRF Router Configuration mode. Not all parameters are configurable on non0 VRFs.
This configuration does not apply to IGMP snooping and DvR Leaf.
Multi-area SPB boundary nodes with remote IS-IS enabled do not support IP SPB Multicast Policy .
enable
configure terminal
route-map WORD<1-64> <1-65535>
enable
match multicast-group WORD<0-259>
set {rx-only | tx-only}
set data-isid <1-15999999>
permit
exit
ip spb-multicast-policy route-map WORD<0-64>
ip spb-multicast-policy enable
show ip spb-multicast-policy
ip spb-multicast-policy apply
Creating an IP SPB Multicast Policy globally.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#route-map rtest 210
Switch:1(route-map)#enable
Switch:1(route-map)#match multicast-group McastGroup
Switch:1(route-map)#set data-isid 210
Switch:1(route-map)#permit
Switch:1(route-map)#exit
Switch:1(config)#ip spb-multicast-policy route-map rtest
Switch:1(route-map)#ip spb-multicast-policy enable
Switch:1(config)#show ip spb-multicast-policy
            SPB ROUTED IP MULTICAST POLICY - GlobalRouter
ENABLE     RPOLICY
TRUE       rtest
Switch:1(route-map)#ip spb-multicast-policy apply
            Creating an IP SPB Multicast Policy on VRF1.
Switch:1>enable
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#route-map rtest 210
Switch:1(router-vrf-routemap)#enable
Switch:1(router-vrf-routemap)#match multicast-group McastGroup
Switch:1(router-vrf-routemap)#set data i-sid 5679
Switch:1(router-vrf-routemap)#permit
Switch:1(router-vrf-routemap)#exit
Switch:1(router-vrf)#ip spb-multicast-policy route-map rtest
Switch:1(router-vrf)#ip spb-multicast-policy enable
Switch:1(router-vrf)#exit
Switch:1(config)#show ip spb-multicast-policy vrf VRF1
            SPB ROUTED IP MULTICAST POLICY - VRF VRF1
ENABLE    RPOLICY
TRUE        rtest
Switch:1(config)#ip spb-multicast-policy apply vrf VRF1
