Graphing IPv6 VRRP Statistics
Use the following procedure to graph IPv6 VRRPv3 statistics for monitoring the network performance.
- In the navigation pane, expand the Configuration --> IPv6 folders.
 - Click VRRP.
 - Click the Stats tab.
 - Select an interface, and click Graph.
 - Select one or more values.
 - Select a graph type,
click one of the icons in the upper-left corner of the menu bar. Your
choices are:
Line Chart
Area Chart
Bar Chart
Pie Chart
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 InetAddrType  |
 Shows the type of IP address (IPv4 or IPv6).  |
 ChecksumErrors  |
 Shows the number of VRRP packets received with an invalid VRRP checksum value.  |
 VersionErrors  |
 Shows the number of VRRP packets received with an unknown or unsupported version number.  |
 VrIdErrors  |
 Shows the number of VRRP packets received with an invalid VrID for this virtual router.  |
