Delete a Static Route
Delete static routes that are no longer needed to prevent routing errors.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation tree, expand Configuration > IP.
  2. Select IP.
  3. Select the Static Routes tab.
  4. Select the static route you want to delete.
  5. Select Delete.
