Use this procedure to globally enable IP Multicast over Fabric Connect on the Backbone Edge Bridges (BEBs) that directly or indirectly (using Layer 2 switches) connect to IP multicast senders or receivers. By default, IP Multicast over Fabric Connect is disabled. There is no need to enable IP Multicast over Fabric Connect on the Backbone Core Bridges (BCBs).
You must configure IP Multicast over Fabric Connect at the global level, and then enable it on the service option or options you choose.IP Multicast over Fabric Connect uses I-SIDs that start at 16,000,000 and above. The device displays an error message if the Layer 2 and Layer 3 I-SIDs are within this range and the system does not enable IP Multicast over Fabric Connect.
Important
Important
You must enable IP multicast over Fabric Connect globally on all DvR enabled nodes (Controllers and Leaf nodes) in a DvR domain.
  • You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
  • You must create the customer VLANs (C-VLANs) and add slots/ports.
  1. In the navigation pane, expand Configuration > Fabric > SPBM to determine if any I-SIDs are within the default range reserved for multicast..
  2. Select the I-SID tab to determine if the I-SIDs are within the default range reserved for multicast.
  3. In the navigation pane, expand Configuration > Fabric > SPBM.
  4. Select the SPBM tab.
  5. If you want to enable multicast on an SPBM instance that already exists, in the Mcast column in the table, select enable.
  6. If you want to enable multicast on an SPBM instance that does not yet exit, select Insert.
  7. In the Mcast box, select enable to enable IP Multicast over Fabric Connect globally.
  8. Select Insert.
  9. Select Apply.
SPBM Field Descriptions
Use the data in the following table to use the SPBM tab.
Name
Description
Id
Specifies the SPBM instance ID. Only one SPBM instance is supported.
NodeNickName
Specifies a nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>.
PrimaryVlan
Specifies the primary SPBM B-VLANs to add to the SPBM instance.
Vlans
Specifies the SPBM B-VLANs to add to the SPBM instance.
LsdbTrap
Configures whether to enable or disable a trap when the SPBM LSDB changes. The default is disable.
IpShortcut
Enables or disables SPBM IP shortcut state. The default is disable.
SmltSplitBEB
Specifies whether the switch is the primary or secondary vIST peer. The default is primary.
SmltVirtualBmac
Specifies a virtual MAC address that can be used by both peers.
SmltPeerSysId
Specifies the system ID of the SPBM SMLT for this SPBM instance.
Mcast
Specifies if IP multicast over SPBM is enabled. The default is disabled.
McastFwdCacheTimeout
Specifies the global forward cache timeout in seconds. The default is 210 seconds.
Ipv6Shortcut
Enables or disables SPBM IPv6 shortcut state. The default is disable.
McastSpbPimGwControllerEnable
Enables or disables ISIS PLSB Multicast SPB PIM Gateway controller. Disabled by default.
McastSpbPimGwGatewayEnable
Enables or disables ISIS PLSB Multicast SPB PIM Gateway. Disabled by default.
StpMultiHoming
Enables or disables MSTP-Fabric Connect Multi Homing.
The default is disabled (false).
BVlanOrigin
Note:
Exception: not supported on XA1400 Series and VSP 8600 Series.
Shows how the B-VLAN was created. The values can be config for manual configuration using CLI or SNMP, or dynamic through Zero Touch Fabric Configuration and Auto-sense. The default is dynamic.
