This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to configure FA authentication for ports that are operating in Auto-sense mode.
Configuring FA message authentication globally:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense fa message-authentication
The following table defines parameters for the auto-sense fa command.
                                 Variable  |
                                 Value  |
                                 authentication-key WORD<0-32>  |
                                 Specifies the authentication key value.  |
                                 message-authentication  |
                                 Enables Fabric Attach (FA) message authentication globally, for ports that operate in Auto-sense mode.  |
