Viewing the foreign SA cache
View the foreign SA cache to display the (S, G) state the router learns from SA messages.
 - Click MSDP.
 - Click the SA-Cache-Records tab.
SA-Cache-Records field descriptions
Use the data in the following table to use the SA-Cache-Records tab.
 Name  |
 Description  |
 TypeInformation  |
 Shows the SA cache type. The SA cache type can be local or foreign cache.  |
 GroupAddr  |
 Shows the group IP address of the SA cache entry.  |
 SourceAddr  |
 Shows the source IP address of the SA cache entry.  |
 OriginRP  |
 Shows the RP address of the SA cache entry.  |
 OriginatorAsNumber  |
 Shows the AS number of the originator.  |
 RouteType  |
 Shows the type of route used for Reverse Path Forwarding checking. The value can be rip (1), ospf (2), static (3), bgp (4), isis(5) or none (6).  |
