Configuring an ACE TCP flag
Configure ACE TCP flag entries to have the filter look for packets with a specific TCP flag.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click Proto.
 - Click the TCP Flags tab.
 - Click Insert.
 - Specify the operator for the TCP flags entry.
 - In the List box, specify the TCP flags to match.
 - Click Insert.
TCP Flags field descriptions
Use the data in the following table to use the TCP Flags tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 List  |
 Specifies one or more TCP flags—none, fin (finish connection), syn (synchronize), rst (reset connection), push, ack (acknowledge), urg (urgent), and undefined.  |
 OperMask  |
 Specifies the mask value.  |
