Use this procedure to enable Dynamic Nickname Assignment and specify a nickname allocation range.
You must disable Dynamic Nickname Assignment before you can change the nickname allocation range.
 - Select SPBM.
 - Select the Globals tab.
 - To enable the Nick-name server, select enable for NicknameServerEnable.
 - In NicknameServerPrefix, type a prefix.
 - Select Apply.
Use the data in the following table to use the Globals tab.
                                 Name  |
                                 Description  |
                                 GlobalEnable  |
                                 Enables or disables SPBM globally. The default is disabled. To ensure proper cleanup of MAC tables after you disable SPBM, save the configuration, and then reboot the switch.  |
                                 GlobalEtherType  |
                                 Specifies the global ethertype value as 0x8100 or 0x88a8. The default value is 0x8100.  |
                                 NicknameServerEnable Note:
                            Exception: not supported on VSP 8600 Series or XA1400 Series.  |
                                 Enables or disables the nickname server. The default is disabled.  |
                                 NicknameDynamicAllocationStatus Note:
                                 Displays the Dynamic Nickname Allocation service operational status.  |
                                 NicknameServerPrefix Note:
                                 Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default is A.00.00.  |
