Edit PIM parameters for an interface to customize the PIM configuration.
Before you change the state (active or passive) of a PIM interface, first disable PIM to prevent instability in the PIM operations, especially when neighbors exist or when the interface receives streams.
- In the navigation pane, expand the following folders: .
 - Click PIM.
 - Click the Interfaces tab.
 - Edit the fields by double-clicking on them, and then select or type the new value.
 - Click Apply.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the interface Index. This variable is a read-only field.  |
 Address  |
 Shows the IP address of the PIM interface. This variable is a read-only field.  |
 NetMask  |
 Shows the network mask for the IP address of the PIM interface. This variable is a read-only field.  |
 Mode  |
 Shows the configured mode of this interface. The valid modes are SSM and sparse. This variable is a read-only field.  |
 InterfaceType  |
 Specifies if the interface is active or passive.  |
 DR  |
 Shows the router with the highest IP address on a LAN designated to perform these tasks.  |
 HelloInterval  |
 Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default is 30 seconds.  |
 JoinPruneInterval  |
 Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default is 60 seconds.  |
 CBSRPreference  |
 Configures the preference for this local interface to become a C-BSR. The C-BSR with the highest BSR priority and address is the preferred BSR. The default is –1, which indicates that the current interface is not a C-BSR.  |
 OperState  |
 Indicates the status of PIM on this interface: Up or Down.  |
