Globally enable or disable EAP on the switch. By default, EAP is disabled.
Global field descriptions
Use the data in the following table to use the Global tab.
 Name  |
 Description  |
                                 EapolVersion  |
                                 Displays the EAP version on the switch.  |
                                 AccessControl  |
                                 Enables system authentication control. EAP is disabled by default.  |
                                 NonEapRadiusPwdAttrFmt  |
                                 Specifies the password attribute format for non EAP RADIUS authentication.
                                 NonEapRadiusPwdAttrKeyString  |
                                 Specifies the attribute key string for non EAP RADIUS password.  |
                                 ClearNonEap  |
                                 Clears the NEAP session that is learned on the switch.  |
| AutoIsidOffset Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                            Specifies the Auto I-SID Offset value. |
| AutoIsidOffsetEnable Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                            Enables or disables the Auto I-SID Offset feature. |
