Reset the platform to reload system parameters from the most recently saved configuration file.
Switch:1> enable
Reset the switch:
Switch:1# reset
Are you sure you want to reset the switch? (y/n) y
The following table defines parameters for the reset command.
 Variable  |
 Value  |
 -y  |
 Suppresses the confirmation message before the switch resets. If you omit this parameter, you must confirm the action before the system resets.  |
