This procedure does not apply to VSP 8600 Series.
Use this task to view UDP statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IP/IPv6 UDP tab.
IP/IPv6 UDP Field Descriptions
Use the data in the following table to use the IP/IPv6 UDP tab.
 Name  |
 Description  |
 IPVersion  |
 Shows the IP address version as ipv4 or ipv6.  |
 InDatagrams  |
 Shows the input datagram statistics.  |
 NoPorts  |
 Shows the number of ports statistics.  |
 InErrors  |
 Shows the input errors statistics.  |
                 OutDatagrams  |
                 Shows the output datagram statistics.  |
| IgnoredMulti | Show the ignored multiport statistics. |
| RcvbufErrors | Shows the received buffer errors statistics. |
| SndbufErrors | Shows the send buffer errors statistics. |
| InCsumErrors | Shows the input checksum errors statistics. |
| Clear | Specifies to clear the statistics. Default is false. |
